awdtsis »
https://forums.nicoclub.com/awdtsis-u38644.html
Wed Apr 19, 2006 5:27 pm
Ok I have a 240 i run circle track in third gear the engine will completely go out untill the engine speed drops to a certain point and then its pulling hard again in 4th gear it does the same thing in 5th gear i can hold it to the floor and its ok. It also cuts out in neutral and it will cut out in different spots depending how hard you push the gas. I put a new fuel filter in changed the computer, it is still sparking when it dies, and the fuel pump is still getting power. I put a test light on one of the injector plugs and reved it up till it died and the test light went out till it come back in again. Any idea's could it be a sensor bad or a wire or ground loose or shorting out? Also the tack and speedo doesn't work and the oil pressure sending unit is unplugged Any help would be greatly appreciated. Thanks,Joe
