Single DIN Aftermarket DVD in OEM Surround
All things Altima Coupe.
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
I know this should go in the A/V section (I put it there too), but thought I would share here in case anyone else was having the same Coupe trouble I did with this.
Finally got everything to fit perfectly with a universal tray from Crutchfield. Not as clean as I had wanted (cant get the HU trim piece on without doing some major cutting into the OEM surround), but MUCH better than the Metra kit.
Closed OpenSide shotDVD hack switch close up
noshift
Car: 07 altima
looks good, but you should have put the switch somewhere else, so its hidden.
Coupeguy23
Car: 2006 G35 coupe sport
noshift wrote:looks good, but you should have put the switch somewhere else, so its hidden.
migs7585
Car: 08 Altima Coupe 2.5s Super Black
Ya the metra kit is garbage, looks really cheap. I just installed mine but still havin trouble with my ipod adapter. Pocket for the metra is s*** too. Comes right out and doesn't fit flush
DJ_B_Easy
migs7585 wrote:Ya the metra kit is garbage, looks really cheap. I just installed mine but still havin trouble with my ipod adapter. Pocket for the metra is s*** too. Comes right out and doesn't fit flush
I even had trouble with my HVAC and the Metra kit. Didnt fit properly and the defrost button would get stuck. POS...go this route if you can.
I thought about putting near or in the fuse box but chose against it, kind of like it out in the open and functional. To each his own I guess...
ESP
Car: 2008 SexyBlack A/C
QFT! Had the exact issue with mine. Hell...if you pushed too hard the entire HVAC panel would fall inside! Plus, it looks like crap. This textured one looks great, man!
DJ_B_Easy
It was so bad that I could actually turn the defrost on and off by pushing on the bottom of the panel, not even close to the button. So much happier with this set-up, worth the extra $ and time to get it done right.
migs7585
Damn. That's bad....I'm goin double din and oem once I have the money
