Single DIN Aftermarket DVD in OEM Surround
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
So after a few weeks of trying to find the right tray to fit under my flip-out DVD, I was finally able to get everything to fit together and installed it this morning. Not quite as clean as I had hoped (couldnt get the HU trim on without doing some major cutting), but much better than the Metra kit.
Closedhttp://i19.photobucket.com/alb...6.jpgOpenhttp://i19.photobucket.com/alb...7.jpgSide shothttp://i19.photobucket.com/alb...8.jpgClose up of DVD hack switchhttp://i19.photobucket.com/alb...4.jpg
bundy26
Car: 2011 Buick Regal turbo
Look sweet.
headhunt3r
Car: Altima Coupe 2.5S w/ CVT
DJBeasy wrote:So after a few weeks of trying to find the right tray to fit under my flip-out DVD, I was finally able to get everything to fit together and installed it this morning. Not quite as clean as I had hoped (couldnt get the HU trim on without doing some major cutting), but much better than the Metra kit.
ClosedOpenSide shotClose up of DVD hack switch
Saved some people clicking
Desire1314
Car: Altima Coupe 3.5SE 6MT
What's that switch for on the side?
DJ_B_Easy
Desire1314 wrote:What's that switch for on the side?
So that I can play DVDs without having the car in park. Head unit has a wire that is supposed to be connected to the parking brake light wire, all you have to do is ground it through a switch and it fools the unit into thinking the parking brake is on.
headhunt3r
Actually... can't you just ground the parking brake wire without the switch? Then you don't even need to flick the switch to watch the DVD's.
DJ_B_Easy
Nope...tried that. My guess is that the HU sends a small current through the wire and if it is constantly grounded, it doesnt sense the loss of current. With the switch, it senses the current, then senses the loss when you flip it, then thinks the brake is on.
Dig?
Broadfield
Car: 1992 240sx
A nice little trick to get perfect edges on your pocket is to glue a long strip of sandpaper down to a flat board. Then simply run the pocket edge back and forth length wise over it. Making sure that the edge of the pocket always stays flat to the sandpaper. A little trickier on the ends since the pocket is long and narrow. But just do it slowly on the ends and make sure to simply hold onto the pocket near the base. It may take a couple minutes per side, depending on how close it is to straight now and what grit of sandpaper you are using..... but it will come out perfectly straight! **Broadfield Installation Tip Of The Day**
