single cam timming and idle?
Fbomb19
Car: 1989 hatch
1996 zenki
1993 se hatch
1998 silver moss kouki
1992 base hatch
1990 hatch - CURRENT
how can i adjust my throttle position sensor and where should a 89 240sx single cam hatch timming sit at? where should it be? i google some of this but i just can find it U_U pls quik replys i need it asap.
canyouSAY240
Car: 89 coupe
sorry if this isnt much help but i know with a TPS is should manly stay at a certian voltage, no i have yet to do one on a 24e, so you may want to check to see what your voltage should be then hook up a meter to it to test it.. the time chain glides on the single cam have a recall, so you may want to check if you still have the ones from the factory. i almost lost my motor to the glide braking. and it did cause a idle problem for me. and make sure your MAS is clean thats whats causing me problems now.
Fbomb19
Car: 1989 hatch
1996 zenki
1993 se hatch
1992 base hatch
i know man. this is just redic! these nissans dont hold up 2 good.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
there is a you tube video search tps 240sx and it shows a guy with a multimeter adjusting it. I watched it last week. its in two parts.
canyouSAY240
Car: 89 coupe
it more the single cams that run into problems. youtube has it all
