single cam power steering hardline hole
Klits562
Car: white s13 coupe
Im leaking power steering fluid in pretty good amounts its all over my intake and all over the hoses. So I took my intake off and reached down in there and theres a long rubber sleeve over the hardline and theres a nice rip in it it feels like it came from the small cylinder thats part of the A/C thats down there. The bracket that holds the cylinder is square and has sharp edges and the hole in the sleeve is in the same spot but i cant imagen this piece causing a hold in the hardline but its the only place i can think it would be leaking from cause the sleeve is soaked in fluid.So my question is can the line be replaced and what would be involved with removing it?
Klits562
bump plz
r3v_v3ng3
Car: 91 fastback ka-t
i think your talking about ps high pressure line. probably mounted on the tension rod brace. there should be a write up somewhere. btw thats what i had to replace on mine when it was leaking and seems like other 240s as well
