http://www.youtube.com/watch?edit=vd&v=Oze4lRv39NM
what would be the best place to start? spark plugs? fuel injectors? coil packs?
pd: my accent is funny i know
This.Easiest way to tell if it has a misfire is to do a balance power test, pull each coil connector off one at a time. If doing that changes the way the engine idles, lowers the idle, then that is where you misfire is at.
LOLAnother way to tell, if the car sounds like a Subaru and seems to really shake when you rev it up.
Yes, you don't need to drive it to feel the difference, just don't rev it past 2500 rpms, for safety measure. But, you should notice right after pulling the coil pack plug if the idle changes. Also ohm test your injectors. If they are not between 10-14 ohms, they are bad.johnshop wrote:will do a balance power test then!
and i have 3 options right? spark plug, coil pack or injector right?
and rev it up while on park right?because if it is while running i can't tell because i have a drive shaft that is loose ( hopefully a one piece is on it's way soon) and car is shaky as it is
