gawdzilla »
https://forums.nicoclub.com/gawdzilla-u19868.html
Sun Jun 05, 2005 6:24 pm
i've done it and tested most of my harness before putting it through the firewall. no where near the engine or the engine bay. i would DEFINITELY recommend you do it before the motor goes in. here's a summary of what i did, and it has worked out pretty good for me so far.
1) do all of the soldering, merging, heat shrinking, etc. outside of the car. this takes a lot of time. studying the pinouts of both cars, burning yourself with solder, etc etc. get an entire working harness together away from the car at a comfortable working spot. trust me, you dont want to be breaking your back under the dash trying to solder, or reaching into the engine bay doing it. i would say there are about 50 soldering connections you need to make, including repairing busted plugs, extending wires, etc. dont bother relooming or prettying up the harness quite yet.
2) once you feel comfortable w/ the harness and it is complete, bench test it.
3) open the pass side door, plug up the F3 harness as if its in the car. let the main portion of the harness dangle out of the door onto the floor, and give it power.
4) of course, using SAFE techniques and common sense (unplugging the battery whenever you do ANYTHING, draining the residual voltage by flipping on lights) test a few things, like spark, fuel, maf if possible, etc. this part was easier for me cuz i have pfc.
5) go back and fix errors. trust me something will be wrong or at least need tweaking.
6) make the harness pretty. loom it up, tape it, whatever you need to do to protect the wires from the elements.
7) feed it through the firewall from bay into the cabin. lay all of the harness thats supposed to be in the bay onto the windshield and out of the way
8) now drop engine in and start plugging things up.
i suppose its possible to plug everything onto the motor first, then do the feeding through the firewall. but i imagined the way i described above to be easier, since thats how you extract a motor. let me know if you have any questions about the wiring. its pretty fresh on my mind still cuz i finished it up very recently. i am doing late r32 rb26 into obd1 s14
Modified by gawdzilla at 9:44 PM 6/5/2005
