Simple wiring problem?Rb25det into 300zx
fast_s14
Car: 94 300zx
I have everything wired up, and my fuel pump is not coming on. I checked and my ecm is not grounding my pump relay, thus not kicking on my pump. If if run a jumper to the ground on the relay the pump will naturally kick on. I do have contiunuity from the black with pink stripe wire to the relay so i know i have a good connection there. Anyone have anysuggestions on what to check? Am i missing something?
Car:93 300zxengine: r33 rb25det
thanks josh
craz4240
Car: 1995 240sx w/rb20det
If the right wires are hooked up i dare say the ecu may be bad.
Carl H
bypass the fuel pump control module, see if that works.
fast_s14
Car: 94 300zx
Does anyone know what signals the ecu to ground the pump? I was thinking it probably was the starter signal wire off of the ecu, but im not 100 percent sure.
thanks josh
Carl H
ecu provides ground for the pump relay.
fast_s14
Car: 94 300zx
i figured out my problem this afternoon. I traced the black/pink wire to the ecm connector and it was in pin 17 instead of pin 18 for some odd reason. I swapped it out and vola the pump works correctly now. I am confused on why the wire was in the wrong position tho.
Carl H
weirder things have happened man.glad to hear you got it started.
