Final outcome = simple & clean.
^This. I've been eyeing 10mm spacers for a few months now, but I haven't pulled the trigger because I didn't know what would be necessary.mmx23z wrote:what size spacers did you use, if you don't mind me asking?
Nice stack hahaLoop wrote:![]()
I saw that as well. More pics please?alphapig wrote:I spy 240z on meshies
ive been contemplating 15's, but also havent pulled the triggerIBCoupe wrote:^This. I've been eyeing 10mm spacers for a few months now, but I haven't pulled the trigger because I didn't know what would be necessary.mmx23z wrote:what size spacers did you use, if you don't mind me asking?
20mm front, 25mm rear.mmx23z wrote:what size spacers did you use, if you don't mind me asking?
BC Racing, not completely lowered.coderedk wrote:what drop are you running
Thanks Ricky. Try calling me again and if I don't respond leave a voicemail or text. The best way to contact me is via email since sometimes I don't receive phone calls or text because of my bad reception in the hills.Mr.Coupe wrote:Car looks nice and clean Vince. I was calling you a few weeks back so we can get together to install those coils. Let me know what you think.
Ricky C.
Ok I will try calling you in the next month so I can make some time from my Bussiness for personal time and get this done. Haven't had a decent day off in I can't even remember. Business has been hopping since the metro expansion line through LA and Culver City. I'll call you if no responce leave a voice mail, send text message and email you. I've been wanting to get those suckers on for the longest, but no time to do so. Thanks bruh you're the best.Loop wrote:Thanks Ricky. Try calling me again and if I don't respond leave a voicemail or text. The best way to contact me is via email since sometimes I don't receive phone calls or text because of my bad reception in the hills.Mr.Coupe wrote:Car looks nice and clean Vince. I was calling you a few weeks back so we can get together to install those coils. Let me know what you think.
Ricky C.
Woah. I think I'll go with 15 and 20, but thanks for posting that, Loop!Loop wrote:20mm front, 25mm rear.mmx23z wrote:what size spacers did you use, if you don't mind me asking?
The Project Kics you're thinking of might be adapters for a different PCD or maybe they're 50mm spacers lol. When I had varrstoen wheels, they came with hubcentrinc rings, which go ontop of the hub, and then you put on the wheel. But when I got spacers for that setup, the hubcentric rings on the spacers AND the hubcentric rings from the aftermarket wheels wouldn't fit together. So I just used the rings for the spacers. You don't have to have hubcentric rings. But I think it's safer, and prevents you from getting vibrations from the bore size differences. I used non-hubcentric spacers for about 4 months with no problems.DJBeasy wrote:Resurrected...
Question for anyone who went ahead with this (including Loop, if you are still around).
How do you go about hub centering the wheels? Obviously the OEMs shouldnt be too much of an issue, although they wont sit on the little lip on the hub anymore, right? I assume these fit over the 66.1 center bore and then just run straight out with no lip on the outside? What are options for aftermarket wheels? Ive seen Project Kics kits that have spacers + these ridiculous looking hub centric rings that are like 2" wide so they fit through the spacer and into the wheel. How did you remedy this with this kit? Never thought about it this far until I actually started to consider purchasing. If they do in fact have a lip on the outside, excuse me for Im an idiot...
Im mainly interested in giving my aftermarket wheels a little extra push out since I run them 8 months of the year, but having the OEMS sit right doesnt hurt a bit either.
EDIT: Being the at times hyperactive Polish ritard that I am, I did not look at more than a handful of products and pictures. I went back in and checked out a couple more and for those that were wondering the same as me, it appears that most DO have an external lip to center the wheel. Still cant figure out what in hell those Project Kics rings are for though...
Poland out...
