Simple WasteGate question.. i searched..
Nismochick240
Car: 95 240sx- BONE STOCK.. for now
I tried searching several ways and found nothing on Nico. I read on some other thread/forum that a 40mm wastegate WILL bolt to a 38mm flange? Is that correct? I bought a T3 super 60 and a JGS 40mm wastegate. I was wanting make sure that it will fit. Thanks guys!
(btw, the Ka-t is coming along pretty good/fast)
MarkEmark
Car: fully-built '95 240sx KA-T
Nismochick240 wrote:I tried searching several ways and found nothing on Nico. I read on some other thread/forum that a 40mm wastegate WILL bolt to a 38mm flange? Is that correct? I bought a T3 super 60 and a JGS 40mm wastegate. I was wanting make sure that it will fit. Thanks guys!
Why did you buy a 40 mm wastegate if you had a 38 mm flange?
Even if it does bolt up, the 40 mm wastegate has 1 mm on each side that'd be overhanging the 38 mm port...i'd think that'd be enough to cause problems...and the LAST thing you want is a leaky wastegate seal....just swap it out for a 38, i'm sure theres plenty of people wanting to upgrade to a 40 mm from a 38...
Iamjohnhayes
Car: 89 Single Cam Hatch
now why would there be a problem using the 40 mm wastegate on a 38 mm hole. i dont see why the size difference would matter if its going out the small hole and into the big one. i could understand if you were doing it the other way.
and besides can't you just take the gasket from the wastegate and scribe the new diameter ont the 38mm flange and enlarge it with a die grinder if you really want to be fickle.
S13FREEAAK
The jgs 40mm wastegate is flanged for the tial 35/38mm flanges. It will work, because that is what I used it on.
And BTW: I'll send the tracking number for the wastegate tonight after I get off work.
Nismochick240
S13Freeaak- got it lol thanks
yea I was just completly making sure... either way I would have prolly keep the wastegate and used it on another project haha! thanks guys!
WDRacing
If you go from a bigger holoe to a smaller then you may have a boost creep issue, going from smaller to bigger would be a benefit if anything...so long as the gasket maintains a seal.
WD
Nismochick240
Cool, so I'm good? just use some good sealer
Brian, did you ever find that fuel rail?
WDRacing
Yeah, I'm holding it right now...LOL. You still want this damn thing?
A decent gasket withy a metal ring should be fine.
Nismochick240
LOL yea, I need it to test out the injectors to see if they fit and stuff... I've all ready paypal'd you some money! I've been trying to get in touch w/ you forever haha
Chezedik
Car: 1991 Nissan 240sx
You don't use sealer, use anti-sieze and a sintered gasket.
Edub1
Car: 89 240sx KA-T
Ok, checked out your car domain but didn't see any pictures of you in there.
Nismochick240
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
wowzers.....^^^^
Edub1
Car: 89 240sx KA-T
Well then, ask and you shall recieve.
I'd just hate to have to come down there and put another X-boyfried on your list. But...
BTW, my B-day is Spetember 15th.
