crzycav86 »
https://forums.nicoclub.com/crzycav86-u9237.html
Tue Dec 21, 2004 2:47 pm
I recently adjusted my ignition timing after doing a timing chain job.. and passed emissions afterward with flying colors
Anyway, I just want to make sure I did the timing correctly..
First, where is your head supposed to be when you're looking at the pulley/pin? I figured that a person's perspective would have a big impact on the readings he gets. I stood as low as I could with the timing gun near the left fender so that I could still see the pin/pulley. Was this correct?
Also, is the tps the little sensor on the right side of the throttle body? I unhooked the little connector that came from it. It was tied to the valve cover pressure relief line. Was this the correct plug to unhook?
This is on a 93 240sx.
Thanks.
