simple timing question
Kaferwerks
Car: 74 VW Beetle 89 240sx xe
89 KA24E
there are 6 identical marks on the pulley, nothing to indicate TDC or degrees.which mark is TDC?
Kaferwerks
the manual i have is showing the marks as:
-5* 0* 5* 10* 15* 20*
book also says time engine around 15* which looks to be the fifth mark.
sound right?
Kaferwerks
bump
slowfkncar
Car: 93 fastback
if im not mistaken engine should always be at tdc. which is second to left mark.
set crank to tdc. cams should be tdcand distributer(ignition timing) should be 15 or whatever your engine specifications are
