Henry G »
https://forums.nicoclub.com/henry-g-u26943.html
Wed Aug 09, 2006 4:55 pm
Black / Pink stripe Black / Pink stripe Fuel pump relayGreen / Orange stripe Green / Orange stripe Transmission neutral switchRed / Black stripe Red / Black stripe ECU relayGreen / Yellow stripe Green / Yellow stripe AC relayBlack / White stripe Black / White stripe ECU powerBlue / Green stripe Blue / Green stripe AC relayBlack / Yellow stripe Black / Yellow stripe Idle air control solenoid powerBrown Any +12V Switched O2 sensor powerRed Red ECU backup powerBlack / RedBlue / Red Black / Red stripe Main ignition power
Using the frsport.com's wiring guide and I'm not 100% sure on which wire to use for the brown wire. Which +12V wire should be used?
