simple running temp question
rva240
Car: 1996 Nissan 240sx SE
I've got a '96 s14. The other day I was driving on the highway and my car overheated. Pulled over. My upper radiator hose came off. People brought me coolant, I filled up, and got back on the road. Now my car won't reach the same operating temp that it used to. Any idea why?
Razi
Car: Moo
Is it running cold now?
rva240
Yeah it's running cold
RiverCitySX
Car: 1993 Nissan 240sx KA-T
You may want to pop your t-stat out. I've seen the wax pellet that opens it explode after over heating then it can stick open.
possibly an air pocket in the cooling system
biggie
Should have replaced the thermostat, anytime you drain the coolant. But new coolant could be keeping it slightly cooler as well.
What was it at before and what's it at now?
rva240
Yeah I'm sure it wouldn't hurt to replace the thermostat, I haven't done that in a while, actually. I always thought that air pockets would cause it to run hot though.
The temp gauge before would be right about halfway up, which I thought was the normal running temp, and now it hardly gets above the "C." I'd like to get it back to 'normal' because my heat doesn't blow nearly as hot, and it's getting pretty cold outside.
Razi
Car: Moo
It's possible that the thermostat is stuck open, or it's damaged and just letting all the coolant through and not letting the engine warm up.
I'd take the thermostat out and check on it.
RiverCitySX
I've seen both hotter and colder temp readings with air pockets. Check your t-stat, you may also want
to check the temp sender (single wire) to make sure its not bad. More than likely thermostat issue. :)
Jmoore124
Car: 1995 240sx Ka-t
2003 Saab Linear turbo conv
(Sold) 1989 S13 red top
The above post is correct. You can get cool or hot readings with air pockets in the system. Go through a bleeding procedure and if that doesn't work then replace the thermostat
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Make sure to bleed the hell out of it. Using one of those spill free funnel kits is the best way.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
when you overheat , you are allso overheating the temp sensitive spring on your thermostat..replace it..but before you add a new one,drill a small hole just smaller than a 1/4 inch and make shure that lines up with the top when you put it in..thats a pesky area to bleed out and the hole will help promote proper bleading of the air from the system.
RiverCitySX
Jmoore, i'm apparently not able to send messages yet, lol.
I'm in richmond va
KA-t w/ eagle rods, BC pistons cometic head gasket and ARP head studs
Turbo exhaust and intercooler are all ISIS
RS enthalpy tune
currently pushing 16psi
