Internals??? Who mentioned anything about internals? You CAN run a T28 with the stock fueling, but what's the point? The injectors and stock MAF are your weakest points in your HP potential. In order to take advantage of the T28 you need injectors that are rated no less than 450cc, a fuel pump, a MAF (preferably 300ZX) and a SAFC or tuned EPROM to control them.Mixmastamunkh wrote:so, if i bolt on the a new turbo (such as the t28) then im pretty much going to NEED to upgrade the internals? and if i get an sr s13/s14 turbo will i still need to upgrade the internals? -but the main qeustion, with a boost control can how high can i safely get the t25 you mentioned up horsepower wise. i set the goal at 250 but if higher that'd be nice. *and what boost would it be with stock internals
-once again thankyou for answering my impolite n00b qeustions.
The new injectors (depending on their size), the z32 maf, a boost controller, ALONG with a Super AFC 2 unit and fuel pressure variable regulator you can get those numbers. The SAFC-II allows you to control the ratio of air to fuel in your engine, thus, if youre adding more boost then you need the fuel in there to compensate for the air.... more boost = more air. more air and less fuel will cause your engine to run lean and that is BBAADDDddddddd... How much psi's do you plan to be boosting on your T25?Mixmastamunkh wrote:okay, so new fuel injectors, z32 maf, (i already have the exhaust) with boost control i'd be able to get that to 250 easily right?
-oh and what kind of 450cc injectors do i need? does it matter what kind, or are there car specific injectors. not many 180sx or CA18 peices being sold around here or on ebay, so where do i find them?
Yeah I know, a lot of people are able to, but its going to depend on the health of the engine, and of course its going to affect longevity. I'm talking about going 100,000 miles instead of 20-50k... But the big thing is that if your driving on the street and running pump gas like most of us, over 250 hp or so at the wheels... one bad tank of gas and you could be risking engine damage.float_6969 wrote:One of our moderators put out over/close to 300hp on the stock bottom end.
