JacobsBaked »
https://forums.nicoclub.com/jacobsbaked-u133694.html
Tue May 12, 2009 6:27 am
Ok, it's definitely the sohc, spark plugs were going in the side. It also said "Nissan 2400 12v" on the valve cover, I don't know if they all say that or not, that might help.
Anyways when I went out there to check I looked again at the pulley that I believe is the power steering, and I see what you're talking about putting the belt on while the fan is there, not a whole lot of room to maneuver but you still have some room nonetheless.
If I'm not mistaken I'm going to put the belt around the 2 pulleys infront of the fan right? If that's the case then I noticed that there were 2 other pulleys below them and to the left a little bit that were also missing a belt, what purpose do those pulleys serve? Do I need to get belts for all 4 of these pulleys or is it one belt for all of them? I'm a little confused here, and don't want to do anything to harm my vehicle, any and all advice is greatly appreciated.
thanks
