Simple mods.
NewBCr
Car: 240sx zenky
Hello guys, i'm from Costa Rica and have a 240sx S14 SE zenky.
motor is all stock, with 170psi compresion in each cilinder, honestly I think the motor is pretty healthy.
I want to make some mods to my motor, win some whp but a can't make my mind.
going turbo (SR20DET) or stick with the KA24DE n/a.
This weekend i'm getting some dyno runs just to see some numbers and to set up a little bit the timing.
What are the first mods that can may be made to my KA24DE???
-WAI?-header?-2.5" exhaust?
any ideas or suggestions on how much is my ka24de will win with this mods?? whp?? torque??
Open opinions!!!!
BIGT94z
WELCOME TO NICO...btw sick ride. well the common easy mods are intake header, exhaust, tune up. the best header for the ka is the hotshot. u can save 150$ and get the obx. those are the 2 best ones. intake do aem or injen. exhaust u can spend alot or a little. i got custom 2.5 from a shop cost 100. do the basic tune up ka's like ngk v powers (there cheap too)...again welcome
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Without boost the KA is not a #'s whore so IMO I would say replace all the stock bushings on the car with the Energy Supsension Poly Bushing Kit. Get a better Spring/Strut set up and make sure everything else on the car is tip top before you go trying to make it all fast. This car handles like a monster so captialize on that.
nismojunkie
another option besides i/h/e that is mentioned sometimes is to get lightweight flywheel/driveshaft. ive heard good things from people that have done that on nico.
NewBCr
Car: 240sx zenky
Thanks for all the answers.
And what about the cometic head gasket, to increase the compression???
What about JWT cams??
coupebuddy
Car: 89 coupe 96 motor 93 harness 91 auto ecu cai,msd,plug wires,12v charged ignition,hyper grounded,stru
rb 25 detbest or tubo ka is the cheapesti want to go to putalandia
JesusLikesKFC
Car: 91 240sx, geo prizm
save 1500, get a used t25 for 200, ebay manifold. gets some good numbers. much luck n welcome to nico....hehe first time doin that
NewBCr
Car: 240sx zenky
So, if I decide to go for the turbo, do I stay with the stock ECU with a piggy back like a SAFC II, NEO apex, emanage, or should a change it to a JWT ECU?? and which JWT ECU should a use??
Thanks for the replies!
JesusLikesKFC
how much are u looking for? personally i would go with JWT ecu. only read good things about it, what im gonna go for in a few months, and skys the limit. havnt looked much into it but im sure other guys will tell u other helpfull tips.
JesusLikesKFC
oh yeah one u hit over 220whp it becomes like crack. ull be happy u chose to go for the snail.
boznuttz
Car: MS13
everyones avoiding the crank pulley option. cheap as hell off ebay. best first bang for the bucks. +1 to added throttle response. ill also buy a lot of junk off jesus. its called the "corey give me a damn discount before i toss a few animals into your room" plan. give me those injectors!!
boznuttz
Car: MS13
btw. check up the two exhaust cams from ka24des, theres a write up for it.
