crzycav86 »
https://forums.nicoclub.com/crzycav86-u9237.html
Sat Aug 07, 2004 6:18 am
What exactly are you having trouble with?
If you mean the halfshafts are spinning when you're trying to get the 6 bolts off, all you need to do is pull the e-brake.
If you're having trouble getting the the bolts off themselves, make sure you're using the right tools. You need one 12mm wrench and another 12mm wrench or ratchet. If you're having trouble, use wd-40 or some other degreaser.
This is all pretty basic stuff, but I wasn't 100% sure of what you were asking. Try to avoid using pronouns when you're trying to explain your problem. Good luck.
