Simple atx-to-mtx question
QuickerThanU
Car: 98,95,94,89 Nissan 240sx
I have a 96 atx 240 that im doing an mtx swap on. The parts for the mtx swap is comin from a 91 hatch. Just wondering if all the parts are compatible with a 96 with the exception of the interior pieces. Thanks.
kermitman
Car: 2004 Titan, 2002 Maxima
you need S14 driveshaftS14 speed sensor
and since you do not have an s14 transmission, you will throw a code for the Cam Sensor that won't be installed on the transmission. You can get the bell housing machined to accept this sensor. Get the lower transmission harness from the hatch to make it real easy
nightkid86
Car: 97 S14 SE
you will also have to drill a hole to mount the CAS
