simple answer
eazyrb20
Car: cefiro a31 rb20det
hi guyz,heres the thing i recently blew my rb20 and had to change it when i got my car back everything was ok.
the problem is tht i dont know wat the guyz at the workshop did but i cannot find the clip tht connects to the O2 sensor nor could i find any wires so i thought ok i'll just reconnect them from the begening but i after three days search every where on the net i cant findout wat wire connects to wat
there r three wires on the sensor black,white and red but i dont know wat wires should b connected to them
i need a simple and clear solution.thnx
danielmcn
cant you just use the same engine harness you had before the new rb went in? sounds like they didnt extend the wires like they need to. follow the harness from the firewall, there is a split in the harness. one section goes to the motor and one goes to the car harness. iirc the o2 and maf plugs will be on the section that goes to the car harness. I can look later and take pics of my harness.
eazyrb20
it was there earlier but i think while taking out the engine or while putting in they must hv chipped it off anyway i want to it from the begining to b sure which means the wires coming directly where they should b coming from.thnx
