Silvia S13 hid lights????
Greddy323
Car: 240sx s13
i want to do hid lights on my s13. will the ebay ones work ok??? how would i hook it up to the low beam H1 bulb
myfirst24010
Car: 1993 240sx, 2004 BMW M3,
on THe fog lights??THe way i plan to do itI bought the H4 conversion kit with the projectorsand then buy the HID for the H4 and throw em onthis is for regular headlights
AutoShadow
Car: 1993 Nissan 240sx
I believe you need HID housing, otherwise you will blind oncoming traffic. Not positive, though. Try a search.
Soravia
Car: 2003 Audi A4 1.8T
put a black tape on the top quarter of the light and it'll have a cut-off for incoming traffic.
LoL
got chub
Car: pearl white 95 240sx
Soravia wrote:put a black tape on the top quarter of the light and it'll have a cut-off for incoming traffic.
LoL
don't do this... HID burn much hotter than regular halogen and you will damage if not destroy the bulb and possibly the headlight (if you have Silvia triple projectors)
drunkNun
Car: 90' 240sx coupe////92' nissan pickup
autoshadow wrote:I believe you need HID housing, otherwise you will blind oncoming traffic. Not positive, though. Try a search.
But.....HID's already blind oncoming traffic even in an HID housing.
AZ89two4Tsx
I have an active post about this too. Btw, I wanted to put HIDs on my triple projectors. You're saying I shouldn't? Someone else said it would be fine.
Here's a link to my thread:
zerothread/336423
sommmatt
Car: 1989 Nissan 240SX
drunkNun wrote:But.....HID's already blind oncoming traffic even in an HID housing.
No joke. I had a stupid cadillac SUV behind me for 40 kilometers on the highway home one night, just sitting there with his stupid lights in my mirrors.
drunkNun
Brake check.
808customz
i did that on my pop ups.....http://www.jdmuniverse.com/for...83658
--if you talkin bout the silvia front end and the lights...theres a way if theres the will
drunkNun
808customz wrote:theres a way if theres the will
Where there's a will, theres a way.
adrianfromthecastle
Car: 1992 Nissan 240sx
retrofit or go home...
drunkNun
Any links to retrofits for s13 flip up lights?
NismoDriver240
Car: 2005 STi
ib4clawhammer
zerothread?id=279159
he wrote that article and i asked a similar question to this and he tweaked
as for retrofitting... http://www.nicoclub.com/articles.php?id=254025
Greddy323
Car: 240sx s13
drunkNun wrote:Brake check.
hahaha
got chub
zerothread/336423
LoL
if you read the entire quote that i made you would see the person said use black tape. dumb idea that is what i said not to do. projectors should be fine with HID.
Greddy323
Car: 240sx s13
so i need the hid kit and a hid housing????? do i need the housing??? or woud it melt the stock housing???
sweets13
Greddy323 wrote:so i need the hid kit and a hid housing????? do i need the housing??? or woud it melt the stock housing???
you need the projector housing(for the retrofit) for the HID bulb. No it will not melt your stock lamp housing.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Things you'll need to make it work properly:
-Projector housings (2.5" housings will work, so long as they have a LHD cutoff. TSX are the most popular for cost/performance)-Bulbs. You'll probably end up with D2S bulbs.-Ballast and ignitor. Depending on where you buy it, this will be the most expensive part. The ballast and ignitor are sometimes one unit or the ignitor is seperate depending on manufacturer or generation. For the average user, either setup is ok. You will need to wire up your low beam circuit to turn the ballast on as the stock lighting switch will burn out quickly if you run the ballast directly off it. Our switches aren't known for being the best already, so you definitely don't want to run that much voltage through it to power HIDs.
In the end, it's a lot of work. But the end result should be worth it. I've been rolling the RHD cutoff since October, and I have to say it's a sound investment to convert to a LHD cutoff. With Sylvania Silverstars, I get flashed by oncoming traffic for blinding them, I couldn't imagine what I'd do to them if I was running a HID setup.
On a sidenote, does anyone know anybody that has taken apart the standard Nissan projector housing for the Silvia projectors? I'm interested to see what they look like and if it's possible to flip the cutoff shield to change the cutoff to a LHD pattern. It would be a cost effective way to swap to the proper cutoff, but it would still leave you with the sub-par lighting output of the silvia projectors.
Greddy323
Car: 240sx s13
ok thanks a lot
Hijacker
'94 F-150
Here's where I found a lot of my info out. It's an all around really helpful site.
http://faqlight.carpassion.info/
