Silvia not starting
Mike09
Hey guy's I have a 89' Silvia with the Ca18de motor and my car won't start. I'm pretty sure It's the Fuel pump but I was wondering if anyone else had an idea. I disconnected the fuel hose after the fuel filter and while cracking over no fuel was coming out so I'm thinking the pump but NISTECH do you have any other idea's of what to check before I spend a couple buck's on 1.Thanks Alot MIke
NISTECH
Break out a volt meter and check for voltage at the pump harness near the tank access in the hatch floor area. See if there is voltage when cranking. Check for ground also. If you have both your pump is shot. If you dont have power check for a blown fuse. If theres no ground, supply one and see if it starts up.
Mike09
Thanks for your help your right on the money. Just dead pump.
