Silvia K's ecu question
implict
Well im about to buy a new ecu here... and its a slivia k ecu... but isnt that fot the ca motor... not the sr20det ( redtop )...... Also the number on it is 63.... IF it does work with the sr then great!
Also what does the silvia k's ecu have doen to it.. like speed limit cut and so on....
:help
implict
cmon...
ride4lame
The silvia K's manual trans ecu is number 62. I think 63 is for an automatic sr20. I have heard it does have a speed cut, but i haven't reached it...
implict
http://cgi.ebay.com/ebaymotors...33596
Is this really a silvia k ecu?
Hijacker
Car: '92 240sx Convertible
'94 F-150
as far as i knew, silvia k was just a trim level dictating that the engine came with turbo/etc. the high end silvia. so it would be the sr20 or the ca18 depending on what model year ecu you get.
ride4lame
I believe that ebay link is for an automatic motor, I am sure this has been discussed though so you canprobly search for it
