silvia headlights and windshield wiper transmission.
Kalypso
My 93 240 with an Sr has the Silvia front conversion.But the headlight wiring is haphazard
- the high beams are not hooked up - - fog lights work but the switch is right behind the ignition key and its about to fall off.- my left light (not the high beams but the regular night time bulb) was blinking on and off. and now it wont turn on,
is there a wiring guide that can show me how to rewire and/or properly set up my silvia headlights?
oh yeah ... and the winner gets free donuts
Modified by Kalypso123 at 8:39 PM 8/14/2007
Kalypso
bump..
please help i've tried a variety of searches and i've find nothing.
180fan
Car: 89 fastback
not much to it. the headlights had 3 wires you'll need to look into. the following info is at the plug that runs to another plug that takes them to your old school factory sealed headlight, follow the wires from there since they change color. pink was common, green was low, red was high. The wire colors are the same left and right, but on the right side they have a black stripe through them.
to fix the fog switch, you can try running them off a relay and use the "headlight flip" button on your console to trigger them as well.
