silvia front-end alignment
tokyo_x-treme_racer
I've had a Silvia S13 front-end installed on my coupe like a year ago and the problem is that the hood doesnt line up flush with the fenders. Passenger side looks fine but on the driver side on the top portion, it kind of sticks out further from the fender line and on the bottom where the headlight is the hood sits like 1/2cm below the fender. Does anyone know what the problem is? I don't think I have a bad Silvia front-end because when I bought it, it was straight. It can't be my car frame because when I had the zenki front-end it was also straight.
240sxjeff
Car: nissan 240sx zenki version
DO you have a bone stock silvia front end? Or do you have some conversion kit with fiberglass and stuff? It sounds like all you need to do is adjust your hood. You can go to a good body shop and they will re align your hood. or you can do it your self. Just loosen the bolts on the hood and realign them slowly until you get it to where you like it then tighten the bolts back up
