Silvia conversion???
Aznboi64
To make the Silvia fit my 93' 240sx fastback all I need is the Headlights, cornerlights, grille, bumper, fenders, hood? Am I missing anything? And is this all plug n play.
bodyman240
you need the headlight brackets also.
Aznboi64
headlight brackets *check* Next? But is it Plug N play just for putting the conversion on? I know I'll have to figure a way to wire up the lights but that should be easy.
ryback
You're missing the engine! That's the best part of the conversion. :D
themadscientist
I have the headlights, grill, corners and headlight supports. (was that too obvious a plug?)
themadscientist
I have all the plugs in their proper place with enough wire on them to hook them up to you wiring.
Aznboi64
Can anyone tell me what year to what year did the S13 Silvia headlights change. I don't meant when teh S13 changed to S14. I've seen two different types of headlights for the S13. One is a standard halogen and the other is projector. The projector one I hear is for 89-92 240sx/S13/180sx cars. Does that mean the projectors won't fit 93-94 240sx? Or does the Silvia S13 projectors fit 89-94'.
the head
Car: working on cars
there are actually three headlights non projector triple projector and dual projsetor with square fog light all lights are interchangeable
themadscientist
mine are double projector.I see the triples only on SR equipped Silvias(Nissan installed at least)The doubles come in the later years of the CAs and were likely an option from the beginningThe squares were early Silvia and the best out of the bunch IMO
SpeedRacer1
Car: 1990 240SX, G35
Heres pics of the different lights.
