node »
https://forums.nicoclub.com/node-u11359.html
Sun Feb 15, 2004 7:17 pm
I pulled my broken speed sensor out to replace it and some trannie fluid came pooring out. Guess what it was silvery in color. No its not some special transmission fluid, It was tiny pulverized pices of gears! . Like one of those kids toys with glitter in it. I also found a few big chunks that poored out with the fluid! Turns out some of these pices jammed up the speed sensor and caused the gear to strip! Hhehe I have been wondering why I was haveing trouble shifting into reverse now I know.
Im going to continue to use the transmission for a few more weeks. I have another motorset that I will will me puting in with a new spec 2 clutch eventually. What type of oil would you guys recomend I put in the broken one for the short term. It still shifts fine the reverse gear is just a little quirky. Way to go nissan engineering.
