silly "technical" question
nyckanny
Ok, this question may not be too technical. But has anyone ever put 4 240sx wheels with tires in thier car. no rolling, but inside your trunk and back seats, is there anyway to make that work if i have a passenger?!?
see, i told u it would be silly
thanks!
Fenvy
Car: 2005 350Z Base 6MT
yes, it's easy, in fact I have fit 18s in my 240sx with tires on them and a passender and no the passenger is not holding on of them on his/her lap
nyckanny
well, ive got an s14, and yes my old s13 could carry more cargo. how can i arrange them in an s14.
Fenvy
2 in trunk and 2 in back seats
or 1 in trunck and 3 in back seats with one of them stacked above the 2
s14 is not exactly a small car, you CAN make it fit
onosqv
Car: '92 240sx Vert
Hatch is easier, but if you have a coupe, it can still work.
For my coupe, when i transported 4 17x7 rims w/ 205/40 tires all I had to do was lower the rear seat, fit 1 wheel on top of that, the other wheel kind of to the side and partially near the trunk "hole" between the seat & trunk, then the other 2 in the trunk.
Just make sure you don't pack other crap w/ you.
I also transported my stockies back the same way once I got the 17's balanced and tires replaced.
Just read you have an s14, yea, even easieeerrrr - sooo much room.
Just a suggestion: use lots of towels or garbage bags - wheel dirt stays on interior cloth for a while.
Fenvy
or use the heavy duty big black trash bag
nyckanny
is the opening from the trunk into the cabin with the seats folded bigger on s13 coupe or s14??
ok, i guess it should work
