here's the site:
http://www.silkroad-jp.com/section/a8.html
I ran it through the babelfish/altavista(japanese -> english) translator and this is what it shat out:
__The high pressure gas charging type mono tube shock absorber of the attenuation quality which stands up smoothly from low speed - it installs attenuation power 8 step adjustment mechanism and corresponds to wide setting.In addition, controlling the occurrence of aeration and cavitation even in extreme use.* Strut type to make inverted system, rigidity and heat dissipation characteristic substantially rise.* Damper, to spring and upper mount assembly conversion.Strut type (inverted system) the pyro ball upper mount, in addition adopting the aluminum rigid mount to the uprighting type shock.* To cover the œÐ dynamic aspect of the damper with the private dust boots, improvement durability.__
so what I take from that is they have an inverted shock, and its 8 way adjustable? (although I dont exactly know what is adjustable:rolleyes)They come with front upper camber plates(pillow ball mounts), and for S13, the spring rates are 8/6, much like flt-a2's and Tein HE.
Another thing is price: 138,000 Yen, about $1250 USD.
So, lets think about this:
Inverted shock, upper front camber plates, an unknown 8 way adjustable part , 8/6 spring rates, and it costs roughly the same as Tein HE's?
Well ****, I think I'd like to give these a try. They sound like they could compete with the flt-a2's and the HE's. Now I gotta find a place to buy them.
Anyone else have an opinion?
