Silicone tube clamps
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
I'll pre-empt my question with this brief story:
Yesterday, a 2004 Honda Accord V6 coupe wanted to play on I-75. No problem ... my car is not fully tuned yet, but I know there's enough power at this point to totally embarass him. I downshift to 3rd from 5th and pin it ... BWAM! I knew the sound well from past experience ... car started bogging and stalled at idle. Dern intercooler pipe popped off! Gotta love it :)
Anyway, I wanted to see what types of clamps you other KATs were using for your intercooler pipe connections. I am using what is supposed to be the best on the market; the clamps that are spring tensioned. However, at this point I'm going back to the regular nut/bolt combo. Let's hear it ...
Nathan
I'm going to be crazy and probably try regular old hose clamps. BUT I'm going to bead my IC piping.
rco8786
SS t-bolt clamps seem to work well.
trpower7
Ditto. T-Bolt clamps are standard fare in the biz. They hardly ever blow if you tighten them down right. If you bead the metal AND use T-Bolt clamps I can almost gaurentee you they'll never blow.
andrave
Car: 1989 Nissan 240SX Coupe
regular T bolts for me, although I might use lined screw clamps when I'm first getting everything together, that way I can place a big order for like 12 or 20 T bolt clamps, whatever it will take, and save some money.
Nathan
Anybody have a line on cheap t-bolt clamps? I wouldn't even really care if they were stainless. I'm talking cheaper than ebay here people :)
Projex240
Car: Dogs , My RIDE
Hey scottie...do you have the beaded ended piping? If you dont, you should be able to use standard ring-clamps(worm gears) to hold to piping on. Id always do beaded piping. T-bolt clamps can be found at jgstools.com for reasonable prices.
-Later,
Josh
scotty-2-forty
Also, FYI, all pipes are beaded ... (big 'DUH' to me if they weren't) ... the clamps just suck as they apparently wont tighten to the point of keeping the pipes in tact. It's the first car I've tried this style of clamp ... highly recommended to me from other performance contacts. Buuuut ... I'm rethinking old school again here :)
Projex240
Car: Dogs , My RIDE
im with the old school. Its proven to work. Did you check out the t-bolts at jgstools.com?
scotty-2-forty
... and thanks. I can get those locally and I already have a couple in use on the TB side. I'm probably going back to utilizing that style again. :)
andrave
a guy on ebay sells like 12 of them for 30 bucks, I think it is... and JGS has them relatively cheaply... shop around, never know what you will find
SloS13
Although my car is down (will live again VERY soon). I ordered some T-bolts from JGS.
Also, nobody has mentioned hair spray. It really sticks the couplers to the piping but not so much that you cant remove them. I use Suave. lol
bruinbear714
SloS13 wrote:Although my car is down (will live again VERY soon). I ordered some T-bolts from JGS.
I'd coat the outside of your piping with a thin layer of rubber cement.
SloS13
So, you think your Kung-fu is pretty good eh?
