Silicone for longer rubber boot/bushing life?
Skibane
Car: 2000 Q45 AE 110K
Anyone periodically apply silicone lubricant (or some other protectant) to their rubber bushings, U-joint covers, rack boots, motor mounts, etc.?
Seems like a spritz every year or so would help protect them from ozone- and heat-related cracking. However, there doesn't seem to be any mention of it in the FSM (or the FSMs of other vehicles I've owned, either).
Worth the trouble?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Wurth. Silicone like WD-40 will accelerate rubber deterioration.
Skibane
IIRC, WD-40 is a "water displacing" petroleum-based lubricant. There's no silicone in it.
What I'm referring to is aerosol silicone (i.e., silicone, propellent, and some liquid vehicle that evaporates shortly after application).
FarFetched
Car: Suzuki SV1000S.
Try to keep rubber parts dry on outside. All lubricants attract dust, dirt, etc. Dirt accumulation is not a good thing, it will increase wear of rubber parts make it hard to inspect as well. Also you want to keep rubber bushings dry to reduce unwanted penetration of lubricant between bushing and eyelet. You know what might happen then, right Just my $.02$ Cheers!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I prefer just to leave them alone, because its not really doing anything to make them last longer... especially when they only last 4 years.
Q45tech
You have so many rubber weather seals, window seals, fixed glass seals, suspension insert bushings, drive shaft isolation and centering bushings............things that should last more than 4 years.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Wurth was developed originally for the exterior rubber parts on the 914.
It will help replenish the oxidized components of the rubber and seal the surface to prevent further damage.
Skibane
FarFetched wrote:Try to keep rubber parts dry on outside. All lubricants attract dust, dirt, etc.
Dry lubricants don't attract dirt.
As it is, most rubber compounds are factory-impregnated with waxes, fillers and other chemicals that improve their resistance to ozone, UV light, oil, etc. None of these chemicals last forever.
