silencer removal
suicide commando
Car: 1993 infiniti j30
hi i found this video on youtube made from a guy in this forum:
http://www.youtube.com/watch?v=LLXhxgVmN10
my question is: is this a stock j30 mufler? because i dont see, at least on mine, any kind of silencer. if it is how do you remove it?
eventually ill instal something nice when i have the extra money but for now this would be nice.
jdurrty
Car: j30
Hahah that's me!
The exhaust on the J30 is a true dual exhaust, with dual cats and dual mufflers, up until you hit that big monstrosity of a muffler sticking out the back bumper(I just called it a silencer for the video). The (silencer) attaches to the exhaust system behind the rear axles with just 2 nuts, 14mm I think. One side of the tubing is bolted together while the other side slips on. Remove the two bolts, give the other side a good wiggle and the silencer should pull right out leaving your J30 sounding roughly like mine does in the video. Good luck!
suicide commando
Ah awesome. Thank you.
suicide commando
So the mufflers are before that big monster in the back? Is the only purpose for that to silence?
jdurrty
Car: j30
Here is a picture of the underbelly of my J30, a little small, but you can get the idea. The crude, green arrow points out the section where the silencer bolts to the mufflers before it, the drivers side muffler is the one that slips on. I cut the pipes halfway between the silencer and the mufflers while welding up a new exhaust system, this is why there are the bents pipes from the silencer, but no silencer. If that makes sense.
suicide commando
so you got rid of it completely? i would like to remove it if i can then run the pipes out to the back.
Talamascan
Car: 1993 Infiniti J30t
About how much does the rear silencer weigh?
yodawill2000
Car: 94 Infiniti J30
I would guess a good 35/40 Lbs.
I cut mine out and ran pipes to the back with chrome tips long ago.
Its actually called a "Resonator".
suicide commando
alright i got rid of this guy now i need to run some pipes to the back. would it make any sense to run bigger pipes after the muffler or should i just keep it the same?
Mkiisupra
Car: 95 Infiniti J30t
Post pictures.
suicide commando
Jdurrty posted a picture^
That's how mine looks now
suicide commando
Yoda what size pipes did you run to the back. Same as stock or bigger?
yodawill2000
Stock
Be sure to leave the hangers intact.
They can use them to hang the pipes.
J30tChumpCar
Car: 1995 J30t Totaled @ Charlotte motor speedway
1994 J30 gutted caged road racer Now with VH45DE!
1966 Chevy Corvair V8 mid-ship conversion
Are you doing this for a performance increase or just to make it sound different?
suicide commando
Mainly just sound
yodawill2000
you get a little drone at cruising.
But it will turn a head when you go WOT..
suicide commando
As it is now without new pipes running to the back with the resonator off its pretty loud at a lower rpm.
yodawill2000
its releasing under the cabin.
It will tone down when you pipe it to the rear.
