RS12Turbo »
https://forums.nicoclub.com/rs12turbo-u46243.html
Wed Feb 14, 2007 6:17 am
Just curious what the tale tale signs of a blown or going head gasket are?
My engine pulls strong, and idles perfect. No over cooling or over heating. Spark plugs looked good about 300 miles ago. Compression was 160 on all 4 about 300 miles ago. No visual oil in the coolant, and no visual coolant on the dipstick.
The reason why I am questioning is because I keep smelling coolant while driving coming through the air vents. I checked the passenger side floor, and there are no signs of a leaky heater core. No coolant puddles on the garage floor either. I'm thinking the coolant smell might be coming from the valve cover breather vapors, and then getting sucked through the air vents........sound possible? Also I had to top off the coolant overflow bottle a few hundred miles after I installed the motor, but I figure I might just had air bubbles in the system after filling the radiator, and it needed topping off from that. Also this morning there was a fresh green oily spot on the floor. I've been cleaning the floor with straight simple green, so the area is kinda green anyways.....so I'm hoping the oil spot just picked up some of the color. I guess I need to clean the floor off, so I can get a clean catch sample . Thanks for any help
