Larz wrote:Oh wait! you have a 2006! No cutting needed. On my 07 (see pics) I just drilled a small hole in the bumper trim piece behind each DRL to slide the wire through, then neatly fed them up to the battery. Then I used 3M tape (15-20lb test from Home Depot Paint dept) to attach them under the out cropping on the bumper. Even after the accident with the drunk driver that totaled my cat, they were still holding on perfectly.
First, sorry that your 07 ended that way.
drunk driving is never good
Anyway, is the 07 the car you have in the "custom DRL" how to write up you did? Or is it your 09? I thought it was your 09 with the new bumper that they fit perfectly. So where are these pics and/or write up? Your signature or something? Thanks again.
