rbsileighty wrote:I also noticed on Signal's site they are using Tein HE's on their drift car, which I found interesting considering I've heard some people call this kit "soft."
Dori Dori wrote:You can't use z32 spindles on an s13. The z32 has a double wishbone (kinda) suspension in the front.
In the rear, however, you can use the aluminum knuckle off of a z32. Keep in mind that the lower strut mount is different on the z32 knuckle. You'll want the n/a hubs btw.
yeswepromise wrote:no they are not using tein he on the drift carsthey are using tanabe dd
rbsileighty wrote:http://babelfish.altavista.com...t=url
Here are the specs on their green car. This is where I saw they had HE's.
Toad[^_^] wrote:http://www.nissanperformancema...40sx/
Big waste of money, but it can be done.
rbsileighty wrote:That is the tomei kit that I have. Which lock bar kits would you recommend?
That website is cool.Dori Dori wrote:They are all pretty much the same, I think materials used are the only variances I've ever seen...with the right resources, you can even have one made.
I got mine from here:http://www.japanesemotorsport....k.htm It's the 12th item down. The prices have gone up though since I ordered. I did a quick conversion (those prices are australian dollars) and it comes to around $147.00 I paid about fifty less. I don't know where else to get them though. Maybe someone else does?
Dori Dori wrote:That's the knuckle in the rear being changed there. The silvias and z32's had the same rear suspension (skyline too), wich is why it's possible so swap them with little modification. I said the front suspension is different and cannont be swapped over, which is true (at least not easily and I've never seen it done before).
