signal light issue halp asap
dernvon
Car: 1995 q45t
1991 Silvia s13
my signal relay is constantly clicking. Signals work when i use them. Replaced relay and switch assembly on the column. What do i do
Q451990
So the lights don't flash unless you're using them?
dernvon
Car: 1995 q45t
1991 Silvia s13
Correct
Q451990
Never heard of that before... Are you sure it's from the turn signal relay? I'd confirm it by unplugging the relay.
Once you're sure it's the relay, I would start by unplugging each lamp assembly to see if the noise stops...
Heath
