Sign of oil on valve cover!
Nissan-S14
Car: 95 Nissan 240SX SE
I had this since I got the car, there is an on going oil leak, (leak as in, small sign of oil on top of valve cover). My guess its the valve seals? Does anyone know what it may be? Is it possible it could be the gasket?
j-z
Car: 95 240sx
where at on top of the valve cover? it may be the filler cap gasket. your valve stem seals are inside the head. theres no possible way it can be those. when those start to go youll see blue smoke coming out of the exhaust.
Nissan-S14
ill take pictures and post them. Cant really explain.
Red-KAT
Car: 1995 240sx-se ka24det
Take off your valve cover seal and replace both the outer and inner seal...
I took mine off and found that the inner seal was never replaced, It was hard and brittle so oil was seeping up one on the valve cover bolts and getting oil all over my engine.
gabossie
Car: Your mom
Yeah, I have the same problem. It's just the gasket, I've just been to lazy to change it.
Nissan-S14
Where can i buy the valve seal? Will auto zone have it or do i have to go through nissan?
base9se
Car: '95 240sx
go get that nissan valve cover gasket....it's normal. Mine has been changed once a year. It's so brittle when you take them off, so get both of them.
ricebike
2002 Quest
2005 Altima
Nissan-S14 wrote:Where can i buy the valve seal? Will auto zone have it or do i have to go through nissan?
aftermarket felpro should have a valve cover gasket set that includes those seals...
or just spend more $ for the same set w/ nissan branded to it + u got free labor anyways?
Nissan-S14
Here are some pics
Nissan-S14
here is another
Nissan-S14
one more
Nissan-S14
no oil in spark plugs, is always a good sign!
240marcuSX
Car: E34 525i
E46 M3
that couldnt be anything inside the head, it looks like the filler gasket has gone bad like previously stated. thats wierd.
ILikeMy240sx
Car: SR Power
yikes that looks pretty bad....
Try changing the inner and outer gaskets and see if that helps. They get all hard with age.
Nissan-S14
Replaced the valve gasket, problem solved. Looks nice and clean now.
