VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Wed Dec 25, 2024 11:50 am
For one thing, you're overlooking the fuel. After two years it's bound to be largely varnish. When we see vehicles like that at the dealership, if the fuel pump is easily accessed (which it is on your M), we pull the pump, dump a gallon of SeaFoam in the tank (yes, they do sell it in gallon jugs), and stir it up thoroughly. We jump the pump to make sure it still runs free, and if it runs but badly, we recirculate it in a pan of SeaFoam until it runs free. Then we pop the fuel line loose at the engine box (in your case at the high pressure pump) and blow through to make sure it's clear. I don't think you'll have issues past the HPFP, with all the pressure they generate the SeaFoam from the tank will usually clear things.
Aside from that, depending how it was stored, you may have serious issues with rotten rubber. Check all of it wherever you find it.
