Sigh, sorry guys i need a little help again. "Transmission malfunction"
Slipdrive
So i changed the spark plugs on my q i used ngk platinums and the car had denso's in there already. Car was running fine before i switched the plugs. Only other thing i did was add an apex i super ground unit yesterday. But the car ran fine last night. When i first stat the car now i get a "transmission malfunction" reading and once i start driving it goes to ok and the car drives fine for the most part. Only thing is the kick down takes slightly longer but not always. I did the at self diagnosis and got a code 3 also after putting in the new plugs the idle is about 300 rpm too high. Any help is much appreciated guys.
Q45tech
TPS connector disconnected or intermitent at TPS on TB.
Slipdrive
Thankyou Sooo Much...
