jamie wrote:You can make them blink but you have to make your own little relay block. Two relays and a diode per side (If I'm remebering right) plus some fun wiring. I wired up our service truck with fancy turn signal mirrors about a year ago. If you want I could try to find the diagram I drew for it. Somewhere lost in the toolbox:)
During the daytime the sidemarkers will blink w/ the turn signal. At night the marker will be on but when you go to use the blinker the power from the blinker will control a relay that provides a ground for the side marker that in turn makes it blink. I think Dodge did it this way on older Cherokees.
jamie, this is exactly the info i was looking for....i did a search on all ur posts but unfortunately i couldn't find any posts from back then =(
do you still remember how the circuit looks like?
