joehughes »
https://forums.nicoclub.com/joehughes-u68244.html
Mon May 05, 2008 4:50 am
Side Steps From SteelCraft:
DO NOT ORDER THESE. I ordered this kit, spent an entire weekend to try to fit a Direct Bolt-On kit onto our vehicles. In order to get it to fit, I would have had to drill out half of the holes on the vehicle they wanted to use for mounting because they did not include the right hardware. I called them on this and they told me that a new kit is already in production and it should be ready in about 6-9 months. They fully admit this kit is a development kit, and that they rushed it out the door to be the first one's out there.
I spoke with Alex at Steelcraft numerous times. He actually asked me to let him know the changes that needed to be made to the vehicle so he can change his engineer's drawings for the production. This doesn't sound like they thought this kit through or even installed one prior to selling the kit.
BULL BAR from Steelcraft:
This was more than a nightmare. After the delay of my shipment for more than 5 days after the delivery date I was told, I finally get this item. It is a hollow piece of TIN. This bar does not look or feel like it can withstand a hit from a piece of drywall, much less anything else.
I tried to install, and after 10 years being a engineer and a mechanic, I can say this is not a good installation. The want you to mount the Bull Bar using the Radiator support, which by the way is extremely weak, and also using the Body Mount Bolt. That is right two bolts to hold this bar up, and one of them attaches to the flimsy radiator support.
Even so, I continued on, after cutting up the undercarrage cover, that's right you have to cut the under support to get their brackets to fit in the car, I was amazed to find out that, OMG, the brackets don't even line up with the bolts on the car. Next to find the directions they have provided with the unit show the mounts go to the wrong sides of the car.
I have spent most of this morning on the phone with their engineering department telling them where items need to get cut, extended, flattened and finally new holes need to be drilled.
After all this my returns of these prodcuts are being refused because I attempted to install, and they only accept returns on UN-INSTALLED items.
Needless to sya I am pissed at Steelcraft and Ultimate Auto Accessories, they will get none of my business for the rest of my fleet of trucks, cars, and work vans. I have pulled my accounts from them and I advise nobody to order from them. They do not have their stuff together.
