Yeah, but the light doesn't normally stay on..Legacy40k wrote:I believe the passanger airbag is supposed to be off unless somebody 80+ Lbs is sitting in the passenger seat.
Yeah, that's exactly what I was thinking.voltronguy wrote:I don't remember what the exact range is, but for the sake of argument let's say it is 5lbs to 80 lbs. If you place any weight in that range on the seat, the light will come on. This is to warn you that the airbag will not deploy. So if for example you had an older child sitting there, you would probably want to move them to the back. If the weight is less than that there is no warning.
