QX4ME »
https://forums.nicoclub.com/qx4me-u5464.html
Sat Jul 30, 2011 3:59 pm
I did this on my already gone 96 Maxima. Got this info from maxima,org. It is vertually a free MOD, and looks even better on Maxima from 95 to 99 (?), as the turn-signal light and side marker are horizontally ligned up next to each other.
It is long time ago so I am not sure if mine is exactly the same. If I remember right, when I turn on the headlight, sider marker turns on; when I set the turn signal on with headkight on, turn signal light and side marker take their turn to be on and off, which looks very nice.
LED should work just fine. If not, just go back to orginal connections. I disconnected the side marker ground and connected it to a turn-signal control which switches between 12V and ground. Was 9 years ago, without schematic now I can't figure out how both lights alternate on and off, not on and off the same time. But it did work very well.
