side marker bulb
MM...Good
Car: 2006 M35x - totaled :(
2007 M35X - Rein"car"nated!! Premium, Advanced Tech, Journey and Aero Package
2013 G37 Convertible - SOLD.
1993 Miata - Zoom Zoom
1999 Honda Shadow Aero 1100
Has anyone eve replaced the bub in a side marker light on the lower front quarter panel? Curious how you got access to the bulb.
Thanks.
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
If you take a look in the FSM in section LT pg. 264 it refers you to the front bumper removal section so it looks like you may need to remove the front bumper cover to change the bulb.
https://www.nicoclub.com/FSM/M/2007_M45-M35/lt.pdf
Larz
Car: 2019 Q70-L RWD
Regardless of the FSM, I wonder if removing the front wheel and wheel well liner might provide access? I have an 09 and it's the same larger body that was used from 06-10. That's how we do the Xenon headlamp bulb and fog light. I can't remember how high one can reach from inside the fender.
EdBwoy
You can access the rear of the lamp/housing through the fender liner and remove the bulb.
However, you can also pop the housing off by squeezing the flexible clip of the housing - that's usually on the front side. So, squeeze the front part, then slide/swing the front out to release the rear.
Let me know if you'd like a demo with pictures.
kmiles
Car: 2015 Q70 3.7 AWD - Hermosa Blue
Sold - 2007 M35x
I replaced my bulbs with LED ones and it was as simple as Ed describes. Only takes a couple of minutes, all done from the outside. They're very similar to many of the interior lights. One of the easiest ways is to cover a flat screwdriver end with tape, so that it doesn't scratch the paint when you pop them out. There are a couple of squeeze tabs on the long ends of the lens that hold it in place. Once you've replaced the bulb, the fixture just pops back in. I recommend testing it before popping it back in as LED bulbs are polarity sensitive.
Larz
Car: 2019 Q70-L RWD
Are you talking about the side (fender) turn indicator or the actual side marker at the base of headlamp assembly?
MM...Good
Larz wrote:
Mon Jan 20, 2020 8:28 pm
Yes - the side turn indicator on the fender between the wheel and the door.
MM...Good
kmiles wrote:
Mon Jan 20, 2020 1:59 pm
That's what I needed - thanks!
