Side flanges and J30 axle question??
drift80
Ok, I have searched many places trying to find out some information about the J30 axle, but to my surprise, i could not find the info I need. If any one of you knowledgeable people here want to help out,that be greatly appriecated, thanks!
Problem: I just got my Nismo 1.5 SSS installed. The kit came with the 5 bolt side flanges(38220-AA016 - 5 bolt ABS flanges) which of course does not fit on the 6 bolt axle of ours(Had to find out the hard way :mad:). I will cut straight to the point, which J30 Axle would I need to fit with those particular flanges?? I know that it has to be pre-95 J30, but I also heard that 92's and 93's are different than 94's:confused: Also, I know that the ABS one's are about half an inch shorter then the none abs ones, so which models do I need?? Meaning, which model will work best with my flanges?? I also heard that many people have tap into their old axles to mate with the 5 bolt axle ends. Which model are they talking about to make that happen?? Also, if anyone know any part numbers, that be a great help also, thanks!:ylsuper
Again, I appreicate all of your comments and suggestions. :icesangel Any information regarding will be greatly appriecated, thanks so much!!
-Billy
