TachyonS14 »
https://forums.nicoclub.com/tachyons14-u10260.html
Tue Jun 01, 2004 8:34 pm
The problem goes like this. I start the car up cold, and there is little to no vibration. Car warms up and drives PERFECTLY for the first few mins. while the temp gauge is in the center. Then about 10 mins. of driving while in operating temperature, I get the vibration through the cabin and steering wheel while at idle and when I hit 2krpms on the dot, it rattles badly in my dash making my keys and everything make lots of noise. This continues till around 3krpms, then it slowly goes away with increasing rpms. My car idles at 650rpm and if i revv it to around 950-1000 no vibration. I mean I barely tap the throttle and it's gone, but not the rattles at 2krpms. This has been a problem since I’ve owned the car (over a year) and along the way I've done:
new spark plugs, plug wires, O2 sensor, cap and rotor, air filter, fuel filter, cleaned the throttle plate (which was very dirty btw) all new motor mounts (left, right, and transmission), I also ran Seafoam through the gas tank, crank case, and brake booster line.
After all that, I though I had narrowed my problem down to fuel since I have done almost everything concerning ignition/spark, and my engine was squeaky clean. So, I tested my fuel pressure to see if it somehow affected my problem. I tested it, and it was just fine, so that means my fuel regulator and fuel pump are getting enough pressure to push to the injectors.
My next logical step was to get new injectors despite that fact that I've already ran many different types of injector cleaners through. But, then It dawned on me that this problem kind of comes and goes which tells me that it is NOT a mechanical problem. I mean if it was a injector or something, It would do it all the time right?
So, what do you guys think I'm looking at? Clean maf? new maf? Coolant temp. sensor? This problem only happens under load, so it's not my suspension or stuff like that. For example, all this can happen while I'm not moving. When the car is in "vibrate/rattle" mode, even rolling up the windows causes fluctuations in rpm's (very slight, but still does it) and increased vibrations. I'm in need of
Hopefully this thread will help people from trouble shooting as much as I've had to if they have this same problem, or one like it.
