I would concur with the vacuum issue diagnosis. Sounds like a typical vacuum leak or potential IACV problem, which would cause the same. Other possible issue is power. Once the RPMs drop, and the alternator slows down significantly, your car may not be adjusting right away from whatever power pull you are making. This is possible but not probable.240hatchsx wrote:I checked most of the vacuum lines and the egr is not fully capped off but is plugged and it's still shuttering
Yes the iacv is on the back of your intake manifold, there is an L hose connected to it should make it a little easier to distinguish240hatchsx wrote:Quick question us the iacv located on the back if the intake manifold ???
