Shut off button only power down engine
hemachayart
Car: 2012 Infiniti M56 Sport tech
Sometimes when I push start button to shut down, engine was off but radio still on, door still locked. What I could do was push start button to turn on and push again to shut down.
What causing that, contacts relay issue?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It can't be a sticky button, but the button could be double-hitting and kicking everything back to Acc instead of shutting off. Next time it happens, look at the indicator lights on the button. If they show "Acc" then you have a bad button, if they show "Off" then you probably have a bad Accessory Relay.
hemachayart
VStar650CL wrote:
Mon May 09, 2022 1:50 pm
Thanks will check. It's normally okay, will wait for it to happen.
hemachayart
Any tips to replace the start button? I know it attached to immo unit. Do I have to take the trim out?
VStar650CL
Technical Expert
That depends on your car's MY, but it looks like on most or all of them it's mounted in Instrument Finisher C. If so, it's easy. Just loosen (but don't remove) the left lower dash, then the finisher should pry out and there will be two plastic pawls retaining the button assembly.
hemachayart
VStar650CL wrote:
Sun Aug 07, 2022 5:40 am
Thanks
EdBwoy
hemachayart wrote:
Sat Aug 06, 2022 1:28 pm
I believe you will find most, if not all, of what you seek to do in this writeup that the good doctor shared with us. Link -
how-to-change-start-button-leds-on-a-20 ... 17206.html
hemachayart
EdBwoy wrote:
Tue Aug 09, 2022 9:40 pm
Wonderful thanks
