Thanks alot driverdriver i got a hold of the tresurer of the club today and he immediately told me to come over and we ran every possible test and finally isolated the problem.cylinder # 6 is not getting any power at all and cylinder # 4 has a loose connection. it was getting to dark out by the time we figured it out. it it is nice out tomorrow i'm going back ou to his place to trace the wires back to the ECU and get it fixed.
Hehe....I told you to crack it open a while back here zerothread?id=106788 Are you not glad you did ? Good to hear the issue is resolved..fingers crossed.. As for the other issues, let the ECU resync with all the sensors..could take a month or so.. Don't lose sleep over it..Elisha wrote:
The whole problem ended up being the ECU again eventho i replaced it less than a month ago. So we decided to rip open the old one and trace the wires back and found some that was just corroded. So we just resoldered them and its all good again.Running on all 6 cylinders again.
Although i still have a little put put in the exhaust and still smells a little bad but no smoke tho. Hopefully that will eventually clear up by itself. And engine a little noisier than normal.
Depends on how much you drive to determine how long it will take to re-learn. At least you have an ECU if this one gives out or you can send the spare one to JWT to get reprogrammed(I doubt you can do it yourself)Elisha wrote:wow it takes that long to resync??
yeah the other ECU has the same problem as well....pin 3 from the left is corroded bad. gonna resolder that as well since i can't get a refund on it. now i'll have 2.is there anyway i can reprogram them myself for more power?
whats JWT? can you gimme a link?DominickJ30 wrote:Depends on how much you drive to determine how long it will take to re-learn. At least you have an ECU if this one gives out or you can send the spare one to JWT to get reprogrammed(I doubt you can do it yourself)
I cleaned the TB/Plenum on the J30 over a month ago..the base idle finally settled to under 1000 rpm last week. This is with my wife (realtor) putting over 300+ miles /week.. I could've set the base idle, but that would've required a complete calibration of all sensors, rather than just the TPS & oxygen sensor (oxygen reads richer and runoff from TB cleaning fluid) which was affected by TB cleaning. The car will settle in..they always will.. .Altimas, sentras, maxima's, Q45..everything I've worked on.. Even a mazda protege included !!. Now, you claim the ECU was corroded even on the replacement..leads me to believe this is a common problem with J30's.. At least the ECU is easy to access (passenger kick panel) Good luck with the car..Elisha wrote:wow it takes that long to resync??
