RoushMustang »
https://forums.nicoclub.com/roushmustang-u267358.html
Sun Aug 21, 2016 8:00 pm
Hey guys,
I have an EX35 AWD Journey, it has 35k on it. I've noticed over the past 5,000k or so I experience a shutter during deceleration. I'm having trouble isolating what is causing this. At first I had thought perhaps the rotors had warped. However, you typically will feel that vibration in the brake pedal and I do not. I find that the vibration is somewhat inconsistent, meaning it isn't necessarily worse during hard vs light braking. I've tried decelerating while the transmission is in neutral, still has a vibration. It has the original Dunlops on it, I did have to replaced one (left rear). I can't see it being a wheel out of balance? I have also noticed that the transmission takes a little longer to go from reverse-neutral-drive. Likewise, during acceleration from a complete stop, I think I'm feeling perhaps some slipping? This could also be me over analyzing.
Based on some reading that I've done on the forums I think a good place to start would be checking the transmission fluid. Any other thoughts or advice, appreciate it!
